Multiphase models-grid size?
Old   June 11, 2002, 03:38
Default Multiphase models-grid size?
Yvonne
Hi everybody!
My problem: How is FLUENT calculating the following? Using multiphase model (Eulerian) and having droplets of the dispersed phase of a diameter, which is bigger than the grid size! Or you have got a diameter wich is smaller than the grid size, but the resulting volume fraction in a cell is higher than the volume fraction, you specified for your inlet conditions! (These things especially occur, if you refined the grid at the wall!) Does anybody know, how to handle that? Does the grid size has to be much bigger than the diameter?
Thank you very much in advance!!! Yvonne
grid size in LES michael Siemens 0 December 26, 2006 23:02
grid size for LES michael Main CFD Forum 0 December 24, 2006 08:33
finite difference formulae for variable grid size yfyap Main CFD Forum 3 March 14, 2006 12:01
Grid size in LES Jin Li Main CFD Forum 1 May 19, 2000 10:02
