Contaminant Distribution in Air-Con Room
Old   June 13, 2002, 10:57
Default Contaminant Distribution in Air-Con Room
Jules
Hello all,
I am doing a study on the distribution of dust particles in an air-conditioned room.
To simplify the model, the room consists of one exhaust, two vents for return of air from the room to the air-con system, and 4 vents for the air from air-con and the environment back into the room.
I was given the values of the flow rate of air thru the exhaust (entirely and directly out into the environment), the 2 vents where air is recirculated back into the air-con system, and the flow rate of circulated air+fresh air into the 4 vents into the room
My question is how I can get the value of contaminant concentration at various time interval at the two vents which the contaminated air goes into the air-con system. I need the value so that assuming the efficiency of filter in air-con is 80%, perhaps I can indicate that the incoming air is being contaminated with 20% of contaminants that escapes into the air-con system.
I think that is the only way to model spread and removal of contaminants with time in an air-conditioned room. Can anyone help me on this?
Modelling airflow distribution in a room gangstagan FLUENT 1 January 21, 2011 12:51
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
heat transfer: air in a room and water in a coil Alberto CFX 2 May 9, 2006 09:56
Air movements in the room Nevill Krik CFX 3 July 28, 2004 18:16
Contaminant Distribution in Air-con Room Jules Main CFD Forum 0 June 13, 2002 10:55
