creating volume by stitching faces
Old   June 24, 2002, 15:30
Default creating volume by stitching faces
Prabhu.B
When I tried to creat a volume by stitching faces, I end up with following Message and Error,
Message:All the faces are selected twice
Error:Is this a open shell?
Any help appreciated.
Old   June 25, 2002, 02:49
Default Re: creating volume by stitching faces
Mustafa Gelisli
Hi Prabhu.B,
There may be two reasons for that. First one is that you do not to select all faces which form a closed region, but I am sure you are carefull about selection. Second one is that your faces are not connected to adjacent faces. Sometimes, two adjecent faces do not share a common edge. They use geometrically similar edges which use different verticies that have same coordinates. You can handle this problem using connetc(verticies, edges and faces -if you have two or more overlaping faces -)command.
Good Luck
Old   June 25, 2002, 04:08
Erwin
I have seen this problem a couple of times when it should have worked normally. I could usually get it to work by re-selecting the faces such that each selected face is connected by an edge to the previously selected face. And tada!, it would suddenly go without a problem.
Old   June 27, 2002, 19:33
Prabhu.B
It worked!! .Got the problem solved by connecting all the edges and faces. Thank you very much for give me the right suggestion.
Prabhu.B
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
virtual faces, volumes creating problems ambermgupta ANSYS Meshing & Geometry 3 July 2, 2010 09:57
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 13:13
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
negative volume & collapsed faces Tipakorn Siemens 1 March 7, 2006 00:41
