Difference between Mixture & Eulerian multiphase ?
Like Tree19Likes
  • 7 Post By Alexandre
  • 12 Post By Lanre
Old   July 18, 2002, 09:52
Default Difference between Mixture & Eulerian multiphase ?
Shankar
Hi Can anybody tell me the major difference between the Mixture and the Eulerian multiphase models in Fluent? Thanks. Shankar.
Old   July 18, 2002, 10:18
Default Re: Difference between Mixture & Eulerian multipha
Alexandre
Here are the limitations of the two models. In my case, the lack of energy equation required to use mixture model.
Mixture limitations :
You must use the segregated solver. The mixture model is not available with either of the coupled solvers.
Only one of the phases can be compressible.
Streamwise periodic flow (either specified mass flow rate or specified pressure drop) cannot be modeled when the mixture model is used.
Species mixing and reacting flow cannot be modeled when the mixture model is used.
Solidification and melting cannot be modeled in conjunction with the mixture model.
The LES turbulence model cannot be used with the mixture model.
The second-order implicit time-stepping formulation cannot be used with the mixture model.
The mixture model cannot be used for inviscid flows.
The shell conduction model for walls cannot be used with the mixture model.
Eulerian model limitation
Only the k- models can be used for turbulence.
Particle tracking (using the Lagrangian dispersed phase model) interacts only with the primary phase.
Streamwise periodic flow (either specified mass flow rate or specified pressure drop) cannot be modeled when the Eulerian model is used.
Compressible flow is not allowed.
Inviscid flow is not allowed.
The second-order implicit time-stepping formulation cannot be used with the Eulerian model.
Melting and solidification are not allowed.
Species transport and reactions are not allowed.
Heat transfer cannot be modeled.
The only type of mass transfer between phases that is allowed is cavitation; evaporation, condensation, etc. are not allowed.
aremu, Sheloski, Paria and 4 others like this.
Old   July 18, 2002, 11:12
Shankar
Hi Thanks for your response which shows the limitations of both the models.But what is the major difference between these two models.Thanks. Shankar.
Old   July 18, 2002, 14:30
Lanre
The major difference between the mixture model and the Eulerian multiphase models is that for the mixture model you solve ONE momentum equation for the n-phases being transported while for the Eulerian multiphase models you solve N momentum equations for the n-phases.
Addressing the interaction between phases is also different. In the mixture model, this is modelled through an algebraic relationship...quite simple. In the Eulerian multiphase models, the interaction is addressed by incorporating source terms, which contain a drag function. The drag function is typically empirical.
Old   July 18, 2002, 17:11
Default Re: Thanks
Shankar
Thanks for your reponse.
Old   September 11, 2015, 04:52
heng03313 is on a distinguished road
Hi, could anyone shed light as to why Eulerian multiphase cannot have compressible flow?
heng03313 is offline   Reply With Quote
Old   October 7, 2015, 08:45
SJSW is on a distinguished road
2003
http://jullio.pe.kr/fluent6.1/help/html/ug/node733.htm
It's not allowed to use compressible flow with Eulerian model.
Inviscid flow is not allowed as well.
2006
https://www.sharcnet.ca/Software/Flu...ug/node950.htm
You can define only one compressible fluid phase.
Another compressible fluid phase could be achieved by UDF.
Inviscid flow is still not allowed.
However, I can't succeed simulating the bubble injected from a mass inlet at the bottom of a half-filled tank using ANSYS14. The bubble is phase-2 and compressible.
It seems that some tricks should be adopted.
Could someone kindly help, please?
SJSW is offline   Reply With Quote
mesh size in Eulerian multiphase flow - liquid/solid mixture microfin FLUENT 4 December 23, 2016 13:55
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 05:29
mixture model or multiphase model in my UDF? aleisia Fluent UDF and Scheme Programming 0 June 8, 2011 13:25
A question about UDF utility in mixture and multiphase model aleisia Fluent UDF and Scheme Programming 0 June 7, 2011 16:32
Tee Channel (Mixture and Eulerian Multiphase Mode) Pathway FLUENT 0 January 23, 2007 02:22
