grid problem
Old   July 18, 2002, 10:20
Default grid problem
seb
Hi. Can somebody tell me if it's possible to create hangin node on a edge in Gambit. Thank you for your help.
Old   July 18, 2002, 14:26
Default Re: grid problem
Lanre
Hanging nodes are created during grid adaption in FLUENT. You can't create hanging nodes in GAMBIT.
Old   July 18, 2002, 22:40
Elana
Jus to clarify..Wht are hanging nodes. and when are they used for?
Old   July 19, 2002, 04:10
Gavin
Hanging nodes: when you need to refine an area of a mesh due to lack of detail in your solution (BL maybe), for each face within selected region, a node is imposed in the centre, thus dividing the cell face into four. This node is known as a "hanging node". It is a method of selective refining, and is usually applied to cells of certain gradient (y+ for example).
Old   July 19, 2002, 09:13
Laika
I have a different understanding of what a hanging node is.
before refinement (two cells)
after refinement (5 cells)
: a-----b-----*
In my understanding, a is a hanging node, and b isn't.
Laika, still orbiting
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
[ICEM] problem to merge HEXA/TETRA grid bikino ANSYS Meshing & Geometry 6 January 30, 2011 12:20
unstructured grid problem jack Main CFD Forum 3 September 18, 2008 03:55
Re: Convergence problem for refined grid CFD_Novice Main CFD Forum 13 February 17, 2008 22:56
problem with grid dimension nisheet goyal Phoenics 1 June 18, 2001 09:28
