Boundary Types in Fluent 5/6
Like Tree3Likes
  • 1 Post By Oresko
  • 1 Post By Ashu
  • 1 Post By Soma
Old   July 21, 2002, 15:57
Default Boundary Types in Fluent 5/6
Oresko
Good Day,
I'm new to Fluent, and have a very simple, if not silly question that has been bothering me. I have been working through Gambit, and notice that when I want to specify boundary types (with Fluent 5/6 set as the solver), there is no INFLOW boundary type available. An OUTFLOW boundary type is available, along with INTERIOR, INTERNAL, MASS FLOW INLET etc..., but there in no "simple" INFLOW type ? If I change the solver to FLUENT 4, an INFLOW boundary type is available.
Why is there no INFLOW boundary type available for Fluent 5/6, and what should be used in place of it ?? I'm using Gambit 2.0.? and Fluent 5.
Thanks,
John
amin_gls likes this.
Old   July 22, 2002, 00:52
Default Re: Boundary Types in Fluent 5/6
Ashu
Use velocity inlet that is known to you. If it is natural convection type use pressure boundary condition. In forced convection cases you need to specify either mass in or velocity inlet depending on your available data or condition.
Hope this meets your requirements.
Old   July 22, 2002, 17:38
Soma
In Fluent 5/6, INFLOW boundary is not VALID because neither magnitude nor direction of the flow is specified here, where in the case of OUTFLOW the two values are obtained from calculated flow as specified in the inlet boundaries. So as advised by Ashu use velocity-inlet to define your inlet boundary conditions.
Old   July 23, 2002, 19:23
Oresko
Thank-you Ashu and Soma for your responses and explanations. Everything is working fine now!
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
asking for Boundary condition in FLUENT Destry FLUENT 0 July 27, 2010 00:55
Meaning of Boundary Types brikksss FLUENT 1 April 26, 2010 01:08
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 06:25
