August 3, 2002, 23:37 |
Importing mesh files from Ansys into Gambit
Hi, I am not able to import mesh files(geometry with mesh) from Ansys to Gambit. In Gambit,in the import mesh files from Ansys option, it is asking for files with extension .FDNEUT, or .ans. In Ansys there is no option to export the files with an extension FDNEUT or ans. I would be very thankful if anyone can solve my problem. Thank you Srinivas
August 5, 2002, 13:45 |
Re: Importing mesh files from Ansys into Gambit
I've never tried this, so I'm only guessing, but I think you need to write a netural file from ANSYS using the CDWRITE command.
August 6, 2002, 10:02 |
hai,
Evan Rosenbaum is right.Long back, I used cdwrite to export the file from ansys. The file will be with *.cdb expansion. It is called archive file in ansys. Loganathan.E |
Converting Fluent mesh files to Gambit neutral files | samuelkc | ANSYS Meshing & Geometry | 9 | April 21, 2021 06:28 |
UDF issue | MASOUD | Fluent UDF and Scheme Programming | 14 | December 6, 2012 13:39 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
