Urgent help needed for meshing in GAMBIT
Old   September 3, 2002, 12:38
Default Urgent help needed for meshing in GAMBIT
John
I am currently modelling airflow around a building with fins to simulate corridors. My domain size is in meters 150L x 50H x 50W and the building i am modelling is 100L x 32H x 12W. 3 pair of fins are located at both sides of the building, namely 2.5m above ground, 13.5m above ground and 29.5m above ground. Each fin has dimensions 100L x 0.2H x 2W. I need at least 4 nodes to be on the width of each fin as I am studying flow along the corridors. How do I mesh such that the fins have a higher mesh density than the domain? i.e. mesh on fins defined by interval size of 0.5 and mesh on domain and building defined by interval size of 1? If I use the subtracted volume, it seems that I could only use 1 interval size for volume mesh. Also, which mapping scheme is recommended for the fins and domain? Urgently seek help from everyone, thanks!
Old   September 3, 2002, 13:16
Default Re: Urgent help needed for meshing in GAMBIT
sri
Hi John,
Having different mesh densities in your domain can be done by either following any of the stratigies :
1)Use a sizing function
2)Create a duplicate face intentionally so that different mesh intervals can be given on each face.
hope this helps you,
sri
Old   September 3, 2002, 23:25
John
Hi Sri,
Thanks for replying . I am currently employing this method:
1. Create geometry for domain, building and fins. Thereafter I unite the fin volumes with the building volume, and then subtracted this united volume from the domain volume.
2. I edge meshed the remaining volume using interval sizes of 1 (x direction), 0.1 (y direction) and 0.2 (z direction.
3. It seems that gambit is taking a long time to mesh the volume as the value stays at 10 percent meshed..has gambit hanged?
4. Is there any better way to mesh this volume? Wld appreciate some recommendations Thankss!!!
John
Old   September 4, 2002, 09:08
anna
After volume substractions, check for vertices, edges and face connectivity.
Instead of meshing edges using number of intervals, use interval count where you will more clearly see the node position and density. You can try to use different edge meshing schemes to get different mesh density in particular areas (your fins, surrounding walls etc.) You can also try to cut your final volume into several ones in such a way to be able to use cooper-scheme for volume meshing, meaning your subvolumes should have base faces for projections (surface mesh -pave scheme), and side faces (surface mesh - map or submap). Try to eliminate (by merging) small edges you may have.
You may get very big volume mesh for that large model, but carefully chosen edge and face mesh sizes should give you reasonably large volume mesh.
anna
[GAMBIT] URGENT!!! "Import from GAMBIT to ANSYS-12.1 (Design Modeler/Geometry)" MDinc ANSYS Meshing & Geometry 13 September 13, 2012 09:26
URGENT!!! "Import from GAMBIT to ANSYS-12.1 (Design Modeler/Geometry)" MDinc FLUENT 1 November 24, 2010 01:59
Urgent help needed patrick FLUENT 1 April 5, 2004 14:51
urgent help needed for meshing in GAMBIT chris FLUENT 0 September 5, 2002 09:18
Gambit Journal File Scripts, Public Database Needed? Jonas Larsson Main CFD Forum 13 March 2, 1999 07:25
