single face with 2 bcs????
Old   August 30, 2002, 16:44
Default single face with 2 bcs????
Shankar
Hi all My geometry has a pipe opening into a container, the tip of the pipe being "velocity-inlet", but when I export this file to fluent, another default entity is created which is a "wall" and this includes the face specified as velocity-inlet.Can anybody advise me on this???Thanks. Shankar.
Old   September 1, 2002, 10:32
Default Re: single face with 2 bcs????
sri
Hi Shankar,
Most probably the velocity inlet might be having two fluid zones on each of its side.If this is the case,then Fluent creates a wall shadow.
sri
Old   September 2, 2002, 05:04
Ashu
If you don't specify user name to the boundary fluent will create the boundary by default as wall. If it is inside the domain then this wall will have shadow wall. Check whether you haven't apply boundary condition to some wall???
Ashu
Old   September 2, 2002, 18:55
Shankar
Yes, the velocity inlet has 2 fluid zones on its either side.And what's a shadow wall, will this affect the calculations?I am not able to specify this unwanted wall as "interior". Shankar.
Old   September 3, 2002, 08:06
Ashu
If both side continuum is same material (fluid or solid) then you can convert this wall into interior. Otherwise there can be problem....
Ashu
Old   September 3, 2002, 14:30
Shankar
Yes both are "Fluid" zones but Fluent says that particular face cannot be "interior" .
Old   September 7, 2002, 00:23
sri
you have to name this as interior in gambit.
sri
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
