PLS help about FIDAP
Old   September 5, 2002, 11:03
Default PLS help about FIDAP
carl
Could you tell me whether fidap8.52 can simulate the non-isothermal mold filling(creeping flow) of the nonnewtonian flow ? I only found that the momentum equation of creeping flow is trimed as linear in the documentation which the density is set to be very small. it seems that it can not match the situation of the nonnewtonian flow. Can you give me any suggestion? thanks!
i need help following problem pls pls help gmani CFX 4 March 31, 2009 09:39
Fidap to Fluent Ravi FLUENT 3 July 10, 2008 13:31
user_sub FIDAP doesnt work semetay FLUENT 3 July 22, 2006 19:51
FIDAP and temp dependent mat properties PLS HELP!! SEMETAY FLUENT 1 July 14, 2006 02:04
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 15:56
