help: which VOF model
Old   September 5, 2002, 10:28
Default help: which VOF model
mystic_cfd
hi there
i am doing stirred tank simulations and need to take the liquid surface into account. i don't require sophisticated surface tracking, just something which is robust and will work on a (coarse) grid with sliding mesh.
any experience or recommendations would be very welcome.
thanx
Old   September 5, 2002, 10:49
Default Re: help: which VOF model
Laika
this should be no problem. My experience is that sliding mesh + vof takes very very very long to converge to a physical meaningful solution. Solution: run a moving reference frame model in steady state, and, if necessary, switch tot sliding mesh after convergence.
good luck,
Laika, back in orbit
Old   September 6, 2002, 05:41
alain
hi,
In my experience, VOF isn't very robust and won't works on a too coarse grid (results may be completly unphysical).
If you need to take into account that there is a free surface but it's deformation is small enought to don't interfere with flow field near the agitator you can use a free slip wall.
Best regards
VOF Model or Mixture Model mems21 FLUENT 2 March 9, 2010 10:37
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 22:00
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 09:57
help needed for vof model yan FLUENT 3 December 16, 2005 01:17
Moving mesh or VOF? Giovanni Main CFD Forum 16 September 24, 2001 08:25
