Reading table file
Prev Previous Post   Next Post Next
Old   September 20, 2002, 14:19
Default Reading table file
MON
Hi Shital
First, i write a program on C++(((EssaiC.cpp))using some standard C-language attributes(fscan...).this program can read the data from table_file to an array called table[i] [j]. this program run and can read the array table[i][j] ********* ********* /********EssaiC.cpp*****/ #include<iostream.h> #include<fstream.h> #include<stdio.h> main(void)
int i,j;
float table[10][20];
FILE *fichier;
float temp;
fichier = fopen("Meteo.txt","r");
for (i=0;i<3 ;i++)
{ for (j=0;j<1;j++)
fscanf(fichier,"%f", &temp);
table[i][j] =temp;
cout << "\nla valeur de i\t" << i;
cout << "\nle valeur j\t" << j;
cout << "\n\nla valeur de table est:\t" << table[i][j];
fclose(fichier); return 0;
******* ******* Where Meteo.txt is the data file **** **** **** "Meteo.txt"( array [3,3]) 1 2 3 4 5 6 7 8 9 ***** ***** i complie the EssaiC an i can read the values of the arrayarray [3,3]: ***** ***** I write a UDF (UDf profille)(((EssaiFluent.cpp)))using the same standard C-language attributes as EssaiC.i can compile with success but i can't read the array: ***** ***** Essai Fluent #include"udf.h" DEFINE_PROFILE(PERTE_ATM,thread,position) {
face_t f;
FILE *fichier;
real x[ND_ND];
int i,j;
for (i = 0 ; i<1 ;i++)
for (j = 0;j<2;j++)
fscanf(fichier,"%f \t",&table[i][j]);
printf("\\n\n %f \n",table[i][j]);
fclose(fichier);
begin_f_loop (f,thread)
F_PROFILE (f,thread,position)=100*table[i][j]+table[i+1][j]+;;
end_f_loop(f,thread) }
i compile the UDF witout error but when i will print the value of the array .(look the UDF Define profile)but the UDF (Define profile ) can't read correctly the value from data file(Meteo.txt).
What the error in my own UDF? Thanks in advance.
Ridha
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
