Print
Old   October 4, 2002, 13:07
Default Print
MON
Hi every body ! for my UDF (Define_source) i use several "printf()" for debugging. when my UDF is interpreted it work. but, when i run it i see nothing. how can i print things to screen. is there another way to debug an UDF? I work in (Pc win nt4, ntx86) of everybody? thanks and excuse my poor english ************************************************** *****#include"udf.h" #define mu 0.8 /*mu coefficient d<attenuation du spectre solaire*/ DEFINE_SOURCE(cell_Source,cell,thread,dS,eqn)
face_t f;
FILE *fichier;
double source,y,t,time[47],Hs[47];
real x[ND_ND];
int i;
y=x[1];
fichier= fopen("Source1.txt","r");/* read data file*/
t=((RP_Get_Real("flow-time"))/3600.);
printf("\n temp=%lf \n",t);
C_CENTROID(x,cell,thread);
for (i =0; i<48 ;i++)
fscanf(fichier,"%lf %lf",&time[i],&Hs[i]);
if ( (time[i] <= t) && (t < time[i+1]) )
source = 0.6 * Hs[i]* mu *exp(-mu*(2.2-y));
dS[eqn]=0; printf("\n\n i=%lf time=%lf Hs=%lf So=%lf \n",i,time[i],Hs[i],source); }
fclose(fichier);
return source;
Old   October 7, 2002, 06:20
Default Re: Print
Keil
The printf is invalid command on PC . You have to use message command. see below.
message("\n\n i=%lf time=%lf Hs=%lf So=%lf \n",i,time[i],Hs[i],source);
Regards,
Keil
Old   October 8, 2002, 02:43
Default Re: Print
Keil
Oops!. the message is Message, m is a capital.
Keil
Old   October 9, 2002, 10:13
Default Re: Print
MON
Hi Keil you can use printf or message to print things to screen . i found my mistake .(i shoud define C_CENTROID(x,cell,thread); in the loup if. Thank you very much
print position of Lagrangian particle? sven82 OpenFOAM Running, Solving & CFD 4 June 16, 2016 08:58
,newbie C++: how to print a matrix? mirko OpenFOAM Programming & Development 3 September 6, 2011 19:15
Print value to screen in user coding? Cb Siemens 1 September 30, 2005 07:29
How to Print Forces Akin FLUENT 1 September 9, 2005 12:26
PRINT VALUE FROM UDF Pravesh Kumar FLUENT 5 October 9, 2002 01:53
