low spped wing computation
Old   November 21, 2002, 05:20
Default low spped wing computation
echo
I am using Fluent6.0 to computate lift/drag ratio of straight wing with aspect ration 12.The airfoil is NFL1050,the computational result of lift/drag ratio is too small,only about 20. The solver is segeregated solver,I have refined grid around the front edge. I have computated 2D airfoil,the result is fine. Who can tell me How I can get good result of wing?
Old   November 21, 2002, 07:35
Default Re: low spped wing computation
Rahul Hiwale
Are you using boundary layer around wing geometry ? Also don't use constant viscosity. For high speed better to go for couple solver. Rahul
Old   November 22, 2002, 07:33
echo
Thank you I have used boundary layer in 2D airfoil, but I can't generate Boundary layer around 3D wing. How I can do it?
Old   November 22, 2002, 11:31
An Modh Coinniolach
Have you changed the options to select faces rather than edges in te Boundary Layer panel?
Old   November 24, 2002, 00:47
mahdi saniee nezhad
Dear sir I have a problem with this title. If it's possible for you please send me your received responses. Very thanks for your attention to my request. With the best regards. Mahdi saniee nezhad
Forward swept wing simulation abid Siemens 1 June 16, 2012 13:26
[Gridgen] Blocking topology for blunt wing siw Main CFD Forum 3 July 21, 2010 13:55
Designing a low aspect ratio wing pranav Main CFD Forum 0 February 8, 2010 14:15
Low Reynolds Number Flow Computation A.M.Yang Main CFD Forum 7 January 22, 2002 12:01
