Boundry Conditions
Old   January 9, 2003, 16:11
Default Boundry Conditions
Parshant Dhand
I made a geometry in Gambit and then created a neutral file and now i exported it to Fluent to solve it.I am able to define materials. My problem is that i am not able to defien boundary conditions, what do i need to do to give boundary conditions under the command define.
Old   January 10, 2003, 01:24
Default Re: Boundry Conditions
zhhuang
Parshant, you should define the boundary condition type in the gambit,just like the inlet,outlet,and wall the liquid region and so on.Then you can specify the value of the boundary condition,just like the inlet velocity is 0.5m/s and the pressure outlet is zero[0].I hope I did not confuse you!
regards zhhuang
Old   January 10, 2003, 20:18
Alamgir
Parshant
U should follow Zhhuang, One thing I need to mention before exporting mesh u need to specify the boundary conditions (BC) in GAMBIT. and the values of that BC u should introduce in Fluent. zhhuang might miss in the last line a word FLUENT.
BYE
ALAMGIR
3D airfoil boundry conditions sarat FLUENT 1 July 15, 2009 08:09
selection of model &setting boundry conditions rajesh FLUENT 0 March 2, 2008 08:22
Boundry conditions!!!! Zaher CFX 2 March 16, 2004 09:25
Boundry Conditions Parshant Dhand FLUENT 2 January 10, 2003 20:25
Non constant boundry conditions Mounir FLUENT 1 February 14, 2001 08:05
