January 16, 2003, 12:06 |
how to reduce y+
Hi, everyone
Well,I guess my question is a stpid one. I had a very simple test model. It was just a pipe with an elbow. I kept adapting the grids, but the Max y+ was still way to high (>300). Can anyone tell me how important the y+ value is and how to solve this problem? By the way the pipe's diameter is just 1m and Re is about 10^5 I also heard about the first grid should be outside the boundary layer? How can I check this? Many thanks Cindy |
January 17, 2003, 12:50 |
Re: how to reduce y+
Your y+ value depends on a variety of conditions such as flow speed. YOu need to look at which turbulence model you are using and what kind of wall treatment you are using. Try creating a new mesh and use a boundary layer on the wall just to see what kind of y+ you get. Y+ will also change if it has not reached a steady state solution.
Ray |
January 17, 2003, 22:12 |
Cindy, yeah!If u use the wall function the y+ should be between the 30-200,if u use the 2-layer model,Y+ should 1-5,the y distance can be determined by the fluent training document.use emperical formula get the Cf,then Ut,after that,the Yp you can get.Then you can mesh your grid with this Yp.
zhhuang |
reduce speed in function of forces | Shortcutter | FLUENT | 0 | May 17, 2011 16:00 |
Reduce Y+ values ? | yannossss | FLUENT | 2 | January 13, 2011 19:01 |
How to reduce the emission of Gasoline engine | kiransh77 | Main CFD Forum | 0 | May 4, 2010 12:45 |
How to reduce time step for Volume Fraction equati | Kushagra | CFX | 0 | June 21, 2008 19:59 |
Very Urgent: How to reduce no of cell types? | Harendra | Siemens | 3 | December 14, 2004 16:13 |
