Coupled interpolation possible??
Old   February 5, 2003, 09:55
Default Coupled interpolation possible??
Rosco
Hi, I must realize studies about a waterblock to cool processors but I need to try about 7 differents thickness for the copper baseplate (power spreading in the block) in order to find the best thickness which give us the better cooling (lowest temperature for die processor).
But I DON'T want to calculate 7 time the flow inside the block because it is always the same. Only thickness of baseplate (under the flow) change and temperature prediction are given in 2 minutes with fluent.
Look at the problem on a 3D block here : http://membres.lycos.fr/roscool/forum/block.gif
So is there a way to keep the flow data inside my water volume and change the solid volume around it? Is interpolation is possible keeping the flow? Or I should calculate all 7 time ? Other solutions?
Thx for answers
Old   February 5, 2003, 11:32
Default Re: Coupled interpolation possible??
Rosco
It's good, I have found the interpolation function.. It works great ^^
urgent help needed (rhie-chow interpolation problem) Ardalan Main CFD Forum 2 March 18, 2011 15:22
Surface interpolation schemes and parallelization jutta OpenFOAM Running, Solving & CFD 0 February 25, 2010 14:32
Some confusion about coupled solver for incompressible flow bearcat Main CFD Forum 0 February 14, 2010 20:40
momentum interpolation for collocated grid Hadian Main CFD Forum 4 December 25, 2009 07:25
Coupled 1D/3D STAR-CD Training CD adapco Group Marketing Siemens 1 November 13, 2002 15:48
