Parallel Processing with NT
Old   February 17, 2003, 02:28
Default Parallel Processing with NT
Amir Khanlou
Hello, I was trying to set up a LAN network for FLUENT parallel processing with Windows XP system but I was not sucessful. I would very appreciate you if you could guide me how to set up the network for that, the error message of the FLUENT is "the network path was not found" while the other features of the LAN network work correctly. Regards Amir
Old   February 17, 2003, 06:01
Default Re: Parallel Processing with NT
heydari
do you have the fluent, parallel ver.?
Old   February 17, 2003, 07:45
Amir Khanlou
yes, I do
Old   February 18, 2003, 22:29
cjtune
I think it's more of a network problem than Fluent's. I've seen Windows give me that error message. Try doing a ping test to your other nodes to see if there's really a functional (not just physical) network connection. I'm not sure about XP but W2k has a file called 'hosts' in the /WINNT folder that helps resolves name addresses to IP addresses, eg. node1.phy.umc.edu = 172.177.0.5. Maybe you need to update that.
Old   February 20, 2003, 03:38
Amir Khanlou
Dear cjtune, Thanks for the help, I tried that. Ping works and I can connect to the other PCs. I even downloaded RSHD software which is recommended by FLUENT for parallel processing and installed on two machines. I also made hosts.txt file for introducing the nodes to my PC but after all, I saw the messsage "network path not found" again while I could run commands on other computers like getting directory of the HDD. still have problem! thanks
Old   February 21, 2003, 11:29
cjtune
Maybe you need to share a folder (set permissions correctly) with a specific name?
Old   March 3, 2003, 14:35
Tony
I have found the FAQ page on the Fluent website extremely helpful. Certain things listed on this page (like the necessity of sharing the FLUENT.INC directory) are not in the installation guide.
www.fluent.com/support/installation/winfaq/fluentpar.htm
Hope this helps,
T
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 09:25
multiphase solver - parallel processing - GAMG thibault_pringuey OpenFOAM Programming & Development 2 August 27, 2013 22:03
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
bubbly flow and parallel processing mvee FLUENT 0 September 12, 2007 05:08
About parallel processing in Linux tuks CFX 10 August 8, 2005 08:22
