March 12, 2003, 21:10 |
DPM drag force UDF
Hi, I am doing submicron particle trajectory calculation. I need to write a UDF for the drag foce with a variable slip correction factor (a function of local temperature and pressure.) Do you know how to obtain the pressure and temperature at the current particle position and current time step? I tried to use the following, but it does not seem to work. Why?
cell_t c = RP_CELL(&p->cCell); Thread *t = RP_THREAD(&p->cCell); real pressure=C_P(c,t); real temp=C_T(c,t); Thanks in advance! hedonist |
DPM drag UDF | Hanz | Fluent UDF and Scheme Programming | 1 | June 28, 2016 16:50 |
Drag coefficient, DPM. | jorge poyatos | FLUENT | 14 | January 20, 2012 13:41 |
formula used for drag force? | kamma | Main CFD Forum | 0 | April 2, 2010 10:21 |
UDF for lift force on a bluff body | sawa | FLUENT | 2 | April 11, 2005 03:06 |
Airfoil Drag Force | wowakai | Main CFD Forum | 3 | October 13, 1998 19:27 |
