3D-mesh Gambit.....
Old   March 8, 2003, 14:22
Default 3D-mesh Gambit.....
SHR
Hi All,
I am trying to generate a complex 3D mesh in Gambit 2.0, in which there is a tank having bottom face as irregular (like undulating ground and not a plane surface) surface and other faces are planer faces.
I coud mesh it and export the mesh successfully, but, in FLUENT 6.0 I am getting the messages " Grid Check Failed" and "NonPositive Volumes Existed" and as I tried to iterate it showed DIVERGENCE.
Actually in Gambit I created only two volumes which I think are Positive only. So where from the non-postive volums came???
I also do not know what is non-postive volume??
Plz. help me find what must be wrong??
Waiting for reply.....
SHR
Old   March 10, 2003, 01:01
Default Re: 3D-mesh Gambit.....
Michelle
Did you check your grid after meshing in GAMBIT? It's probably due to the skewness of the mesh.
Old   March 10, 2003, 04:14
ccc
hi,SHR
which kind of cell,hex cell or tera cell in your mesh?
Old   March 10, 2003, 06:46
Chris
I agree with Michelle. Go check the grid using Gambit. (It's in the same position as the icon for information-volume-mesh, except you have to click the right mouse button) Run a check on all your volume meshes. Gambit should report to you which volume meshes have the problem (e.g negative vol etc)
Old   March 14, 2003, 06:03
Yazid
Dear Mr. SHR
By this time, I think you have resolved your problem.
I would like to share with exprience with non-positive volume message exist. I did exprience a similar case with you.
Here are what I did to fix the problem.
1. The non-positive message will appear in the Fluent
not in Gambit when you deal with virtual volumes. 2. I did some experiments in gambit and read the
mesh to Fluent 3. I deleted suspected volumes, especially virtual
volumes and read the mesh into the Fluent 4. At the end I found what the problem. The problem
was the existence of two volumes, which should be
only one volume. This volume was the virtual
volume. I deleted this volume and recreated
a single volume. 5. I my self do not understand, what is the
physical meaning of non-positive volume.
You must take a good care if you work with virtual volumes. Here is the tip, if you find something that make you frustrated, do the remedy by omitting the suspected volumes, and read the new mesh to the FLUENT, at the end, you will find the cause of the problem and you can fix the problem too.
Regard Yazid Bindar
Old   March 17, 2003, 07:06
SHR
HI all,
Thanx Michelle, ccc, Chris, & Yazid!! for your replies.
I did check the grid(mesh) in Gambit, as U have suggested, but I did not get any clue/warning in Gambit regarding Negative Volume.
Still I am trying to fix the problem.
Regarding Mesh Check in Gambit, I do not know whether I could check it properly, as I doubt now, as to what is the RIGHT PROCESS OF CHECKING THE MESH in GAMBIT.
Please let me know the same in detail so that I can fix this problem.
Dear Yazid, my geometry does not include any Virtual Volume.
Waiting for HELP..
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Successive Mesh in Gambit ashish FLUENT 0 April 28, 2006 00:42
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 01:04
[Commercial meshers] Mesh import from gambit Kaushik Balakrishnan (Balakrishnan) OpenFOAM Meshing & Mesh Conversion 5 April 21, 2005 13:42
