April 8, 2003, 23:39 |
Help!! Why I can't run fluent in batch mode?
After updating to Fluent 6.0, everytime I turn on Gambit, the session is always default-id, even I use "gambit -id myfile" command. The same thing happens when i turn on Fluent (I used "fluent 3d" command, but I still have to type "3d" under the x-window)
It is not a big deal when using graphic mode. But right now, I have to run Gambit and Fluent in batch mode. Because of the above problem, I can't get into the batch mode. The x-window is always there. Does anyone know why? Many thanks Cindy |
Run Multiple Files in Batch | nickninevah | STAR-CCM+ | 6 | October 12, 2017 06:17 |
how to create input file to run fluent in batch | Aireen | FLUENT | 6 | November 21, 2016 08:27 |
Running fluent with udf in batch mode | zonexo | Fluent UDF and Scheme Programming | 2 | March 10, 2012 07:50 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
problem with running UDF in batch mode | James | FLUENT | 0 | June 6, 2006 06:49 |
