heat source problem
Old   April 8, 2003, 21:54
Default heat source problem
John
Hi
I met a problem about a heat source in a room. For example a rectangular heat source. If we should give the heat density (W/m3), how can we define the surface wall of the heat source in boundary conditions either the heat source material is same as the media in room or different?
Can anybody give my suggestion about this? Thanks
John
Old   April 9, 2003, 13:08
Default Re: heat source problem
Evan Rosenbaum
You can either define a solid in the geometry, make it a wall and apply the heat to it, or you can use the PATCH command to apply the geat generation directly to specified cells.
source terms-convergence problem alanlove FLUENT 0 March 28, 2010 06:47
Missing heat source Phil FloEFD, FloWorks & FloTHERM 9 June 19, 2008 10:33
moving heat source Mehdi FLUENT 0 March 24, 2008 17:32
Problem in giving heat source Sireesha FLUENT 1 July 10, 2004 17:54
Heat Generation as time dependent problem Denis Kadito FLUENT 0 April 17, 2001 16:28
