Buiding fire simulation
Old   April 17, 2003, 11:03
Default Buiding fire simulation
newer
Hi:
I use the software Fluent 6.0 to calculated the fire in the enclosure. The fire is taken as heat source. I met a problem about fire source. When it is taken a heat volume source, only the heat density is given, but the heat transfer by free convection caused by the increase of air temperature is very slowly. If we taken it as hollow cavity and give the heat flux of the surface, the calculation would not converge. Who can give some suggestions on fire simulation for me? Thanks.
AVL fire CI engine simulation neeed HELP ! Mohsen khalafi AVL FIRE 1 September 10, 2018 10:32
NEED HELP on IC engine simulation with AVL FIRE! Mohsen khalafi Main CFD Forum 2 February 6, 2014 07:47
smoke (fire simulation) matt Main CFD Forum 0 January 5, 2007 04:45
FIRE simulation T.H. Ko Siemens 3 July 24, 2003 23:18
Temperature errors on fire simulation? raymond Siemens 0 January 10, 2002 20:32
