wall shear stress
Old   May 27, 2003, 09:51
Default wall shear stress
lingo
Hi£º
I need to know the distribution of shear stress all over the flow domain in a minisize centrifugal blood pump.However,I only find wall shear stress in post-processing.Who knows how to get the distribution of shear stress all over the flow domain?Thanks a lot!
lingo
Old   May 27, 2003, 14:35
Default Re: wall shear stress
Shiping Liu
First you should make a surface or plane you are interested,then go to display it.
Old   June 2, 2003, 03:40
Alamgir
You can do that by creating line or points all over the domain you like to.. then go to report and click on surface intigral and then on that window if you select shear stress and press compute u will have the value of the shear stress of that point and use a spread sheet to post processing.
bye
Alamgir
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Wall shear stress GamFlu Main CFD Forum 0 June 11, 2011 04:33
Wall Shear Stress GamFlu FLUENT 0 June 11, 2011 03:52
relationship between wall shear stress and TKE winter FLUENT 0 December 11, 2007 17:11
Re: About wall shear stress Mike FLUENT 9 November 17, 2003 14:41
