duct fin system with conjugate heat transfer
Old   July 2, 2003, 23:56
Default duct fin system with conjugate heat transfer
Dibakar Rakshit
My subject is related with conjugate heat transfer through a duct attached with external fin.With the boundary conditions of velocity inlet at the duct entrance and outflow at outlet(high aspect ratio) the conjugateness is attempted to solve by imposinng an extended domain where the fins are present. As the fins are given wall boundary condition with solid facing,drop in temperature as expected is not found.I want to know the reason for this whether my imposed boundary conditions are not appropriate or the drop in fin temperature will be less as obtained.For turbulent flow inside the duct I have used spalart allmaras one equation model. For extended domain I have used pressure outlet for all the three sides exposed to the atmosphere with wall and wall shadow condition on the side which is having the duct and fin system.
conjugate heat transfer in fluent mallika FLUENT 1 September 19, 2007 14:37
conjugate heat transfer san CFX 9 September 15, 2006 00:45
Unreal temperature in conjugate heat transfer CFD joe FLUENT 1 August 9, 2006 09:23
Conjugate heat transfer for film-cooled flat plate Michele FLUENT 0 July 3, 2006 08:42
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
