Help: run FLUENT bechmark
Old   July 11, 2003, 02:58
Default Help: run FLUENT bechmark
SC
For my part-time work, I was required to run a FLUENT bechmark case in AMD Opteron (OS: Linux). I has received FLUNT input data like: xxx.dat, xxx.cas and xxx.txt. The case is urgent, and I have no experience on FLUENT before. Would you kindly tell me a simple way about how to the run FLUENT bechmark case ?
Thanks in advance.
SC
Old   July 11, 2003, 04:56
Default Re: Help: run FLUENT bechmark
SC
Thanks for your consideration. The problem has been solved successfully.
Best regards, SC
batch command to run fluent from nth time step solomon FLUENT 13 August 25, 2015 20:05
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 19:44
Fluent can't run in parallel when hyper threading turning on. field FLUENT 0 May 5, 2011 07:41
How to run fluent in terminal? zjuADou FLUENT 7 July 20, 2005 09:36
To run FLUENT in a 64 bit machine Rucy FLUENT 1 July 4, 2005 08:31
