July 11, 2003, 02:58 |
Help: run FLUENT bechmark
For my part-time work, I was required to run a FLUENT bechmark case in AMD Opteron (OS: Linux). I has received FLUNT input data like: xxx.dat, xxx.cas and xxx.txt. The case is urgent, and I have no experience on FLUENT before. Would you kindly tell me a simple way about how to the run FLUENT bechmark case ?
Thanks in advance. SC |
batch command to run fluent from nth time step | solomon | FLUENT | 13 | August 25, 2015 20:05 |
Parallel run in fluent for multiphase flow | apurv | FLUENT | 2 | August 3, 2011 19:44 |
Fluent can't run in parallel when hyper threading turning on. | field | FLUENT | 0 | May 5, 2011 07:41 |
How to run fluent in terminal? | zjuADou | FLUENT | 7 | July 20, 2005 09:36 |
To run FLUENT in a 64 bit machine | Rucy | FLUENT | 1 | July 4, 2005 08:31 |
