DPM question
Old   July 31, 2003, 06:07
Default DPM question
max
Hi, everyone I have some problems in using Fluent Discrete Phase Model. What I want to do is to simulate a countercurrent scrubber, that is, gas moves upward and contact with the droplets sprayed from nozzles, which was fixed at some elevation in the tower. For the first step of the work, the chemical reaction between the continuous and discrete phase was ignored and the pressure drop was investigated. Firstly, I got a converged solution of the continuous phase and then 86400 droplets with 10 tries were injected to the field, what confused me was there was little difference between the pressure drop with and without droplets, could you give me some advice? And I want to know what does the ˇ°Number of Streamsˇ± mean when define the injection? How to calculate the number of droplets or streams needed to solve the problem exactly? For example, the mass flow rate is 4800m^3/h, mean diameter of the droplet was 0.002m and the inner diameter of the nozzle is 0.1m, how many droplets were needed to simulate the pressure loss? Thanks in advance!
Old   August 6, 2003, 03:45
Default Re: DPM question
max
Could anybody help me?
DPM and LES R.Sripriya FLUENT 6 April 15, 2017 04:41
DPM Initialization Johannes FLUENT 1 June 20, 2007 09:27
DPM residuals for sampler Don Parsons FLUENT 0 April 10, 2007 11:56
Question about dpm akr FLUENT 3 November 13, 2006 12:16
URGENT QUESTION ABOUT DPM EROSION!!!!!! alex FLUENT 2 October 28, 2005 06:33
