dynamic meshing : an err message
Old   August 2, 2003, 03:09
Default dynamic meshing : an err message
Prasad Laxman Kane
Hi All,
I am running a case with dynamic meshing utility. I frequently get following error message :
************************************************** ** Updating mesh to time 1.00000e-02 (step = 00001) Warning: multiple subdivision required on zone 12. Warning: multiple subdivision required on zone 13. Warning: multiple subdivision required on zone 14. Warning: multiple subdivision required on zone 15. Error: Internal error at line 1593 in file 'grid.c'. replace_c_in_f: cell not found Error Object: () ************************************************** **
Where the zones mentioned are moving walls, defined as rigid body and motioned using an udf.
Fluent updates the mesh, but, mesh gets highly skewed and it ends with the above err message.
Thanks and Regards, Prasad Laxman kane
Old   August 6, 2003, 02:06
Default Re: dynamic meshing : an err message
lj
if you have meshes around the wall,you'd better use the interfaces to avoid the problems caused by the linked mesh. try it &good luck!
Dynamic meshing of impeller using fluent shadyenany FLUENT 6 September 22, 2011 16:56
dynamic meshing pronik_zoro ANSYS Meshing & Geometry 0 March 12, 2011 11:01
Dynamic Meshing Tutorial (Valve.c) needed techy Fluent UDF and Scheme Programming 0 January 26, 2011 00:18
6DOF in dynamic meshing & Rotating Frame xhield ANSYS 0 October 25, 2009 04:02
Dynamic Meshing Philip FLUENT 0 February 2, 2006 16:06
