August 22, 2003, 16:21 |
data in Tecplot or Excel
How I can make file that, me it will give data in order to I can him import in Excel or in the Tecplot;
August 22, 2003, 21:19 |
Re: data in Tecplot or Excel
To read a data file in Excel, you can plot the variable you want choosing the Save to file option. Then open it in Excel: a conversion tool will open automatically and will guide you.
Hi ap |
September 20, 2003, 14:23 |
In Fluent you can export your fluent data into tecplot format by choosing
->File->Export File Type is Tecplot Then just select your surfaces and variables. If you are using a tet or triangular mesh, once imported into Tecplot you should "triangulate" all the zones. This may produce some minor differences in connections, but overall results will be the same. Also, newer versions of Tecplot have a Fluent data loader you might want to check out. -Pat |
How to plot a contour from an excel file in Tecplot? | gholamghar | Tecplot | 9 | February 11, 2021 13:43 |
Reading Additional Data Quantities from Fluent into Tecplot | fremder | Tecplot | 9 | December 16, 2016 15:35 |
CGNS vs Tecplot Data Format | LWhitson2 | Main CFD Forum | 3 | July 1, 2011 13:50 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
Tecplot can't read data file from Fluent. | stephen | FLUENT | 8 | November 21, 2001 20:27 |
