Left Handed faces
Old   October 15, 2003, 18:19
Default Left Handed faces
ff
After creating grid interfaces and grid checking in my domain I found left handed faces. Is it possible to correct this problem? Thanks in advice. ff
Old   October 16, 2003, 05:02
Default Re: Left Handed faces
Erwin
Try this: type in the command window:
/grid/modify-zones/repair-face-handedness
Old   October 16, 2003, 05:58
ff
Thanks Erwin. I already used that function but after as well as before I have left handed faces in my domain (without negative volumes). MY final mesh was build using two separate meshes which are merged with fluent utillity tools. Those separate meshes are valid without left handed faces and without negative volumes. After creating grid interafecs left handed faces apears but as I say without negative voluems. Any tips?
Thanks in advice, ff
Old   October 16, 2003, 11:10
type at the FLUENT console:
(rpsetvar 'nonconformal/cell-faces 0)
before creating the grid interface. Make sure that you type the paranthesis as well.
enjoy!
Old   October 17, 2003, 09:34
ff
Thanks,
I'll try. Where I can find more about rpsetvar functions.
Thanks, ff
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
how to treat left handed faces xiang FLUENT 1 March 10, 2003 07:08
