How to get summation of one variable at x directio
Old   October 19, 2003, 21:18
Default How to get summation of one variable at x directio
zhou1
I simulate a 2-D fluid flow in a rectangle channel. I need to get the summation of one transport variable along x-direction at every y coordinate. How can I get it using UDF in FLUENT or other methods? Thanks.
Old   October 20, 2003, 12:01
Default Re: How to get summation of one variable at x dire
ap
I'm not sure if I understood your problem.
If you just need to integrate a variable along x-direction at a fixed y during post-processing, you have to create a line along x-direction, at the y value you want. Then integrate the flow variable un that line, using the Surface Integral tool.
Hi
ap
Old   October 20, 2003, 14:29
zhou1
Yes, i want to integrate one variable along x-direction. I know your method works. However, i need to integrate it at every fixed y value and use this intergration in new iteration. For example, y=0 to 1 and step size is 0.0001. If i use line-creation, it will cost too much lines. So, is there any others method to get this intergration? Thanks.
Old   October 21, 2003, 10:17
ap
You should be able to do that using geometry macros to retrieve positions and then integrate your variable using an algorithm of your choice, but I've neved done it.
This, however requires your grid to be as fine in the y direction as the step you want to use for your y variable.
Maybe there are better and easier methods.
Hi
ap
Additional Variable tav98f CFX 3 April 28, 2011 12:33
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
