November 1, 2003, 05:18 |
Error: unbound variable
When i open my mesh file, from gambit, in fluent for the first time i get the following error message Error: access: unbound variable Error Object: phase-domain? What does this mean and will it affect the results? The grid check is fine. Regards Eric |
November 3, 2003, 06:53 |
Re: Error: unbound variable
hi,
was your problem finally solved? you said earlier: It has to do with how you name your boundaries. For example they should be named inlet_1 or inlet-1 and not inlet 1. A character space causes the problem. did it work or not? let us know David |
November 3, 2003, 10:22 |
Hi David,
Yes it did. I had an inlet named "inlet 1", and when i originally opened the file in fluent i got the error message. I then went back into gambit and changed the name to "inlet_1" and the error message dissappeared. A simple error which probably has no effect on the simulation Eric |
November 12, 2019, 09:37 |
Error: access: unbound variable Error Object: active?
Chien Chih Lin
hi :
I am using Mesh Morpher, I create two control point distribution. However, after updating the Fluent, I receive the error "Error: access: unbound variable Error Object: active? " Can anyone help me? |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Problems with additional variable | Krishna Premi | CFX | 1 | October 29, 2007 08:19 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
