problem about modelling fluidized bed!
Old   November 4, 2003, 20:01
Default problem about modelling fluidized bed!
xfish
hi , i am simulating flow field of the fluidized bed.can anyone tell me that which viscous model should be available in the case of CFB! So grate for your help!
Old   November 5, 2003, 11:03
Default Re: problem about modelling fluidized bed!
ap
Fluent 6.0 and 6.1 allow you can do laminar calculations and turbulent ones using k-eps models (Standard, RNG, Realizable).
Also, you can calculate the granular phase viscosity using Gidaspow or Syamlal correlation for the kinetic contribution, which are based on the kinetic theory.
Schaeffer's correlation for frictional viscosity can be used too.
Hi
ap
Old   November 5, 2003, 22:21
xfish
ap,thanks for you comment! But i means should i use turbulent model or laminar model in simulating circulate fluidized bed(CFB)?i know laminar model is available in bubbling fluidized bed!
Old   November 6, 2003, 08:42
ap
I'd suggest to activate turbulence, in order to better describe the behaviour of the flow.
What are operating conditions (Ug, Gs, reactor diameter and particle density) of the reactor?
You can find many articles in literature where it is demonstrated the influence of turbulence in modeling CFB reactors.
Many authors used a LES approach to describe the turbulence of gas phase. Others developed a modified k-eps model (k-eps-k_p-eps_p) both for gas and solid phases, which gives interesting results.
Both these models are not available in FLUENT: LES can't be used in multiphase calculations, and the k-eps model differs from the k-eps-k_p-eps_p.
Moreover, keep in mind that FLUENT uses an algebraic formulation of the granular temperature balance and not the full differential equation.
Hi
ap
circulating fluidized bed Özgür Baysal Phoenics 10 April 29, 2014 08:39
Fluidized bed Mario Nunez FLUENT 0 January 24, 2008 10:43
Questions about gas-solid fluidized bed simulation Sinferm FLUENT 1 January 31, 2007 14:54
fluidized bed drynig modelling(wet solid+gas) masood yooceframandi FLUENT 2 January 18, 2005 11:55
simulating a fluidized bed yee wan FLUENT 6 December 2, 2002 22:16
