how to specify the source of speceis
Old   November 19, 2003, 23:42
Default how to specify the source of speceis
yangqing
in one case, i want to use a hot gas stream with empirical volumetric heat release rate to specify a fire. No combustion chemistry. but i want to add a source of species (co2, h2o). how to do.
thanks
Old   November 20, 2003, 12:19
Default Re: how to specify the source of speceis
Paul
first define the speces u want.define --> species.and check materials for the species in the system.then you can write a source udf...format for which is given in udf manuals.Then u can attach the source term to the species in the fluid domain.
Old   November 22, 2003, 04:42
yangqing
thanks
Old   November 24, 2003, 03:42
Fonzy
And what about surfacic species source? It looks like there's no way to implement a user-defined source term for surfacic species, besides the surfacic reaction rate. Is it possible? through which UDF macro?
Thanks in advance.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
