turning off error messages and resetting flow time
Like Tree4Likes
  • 4 Post By Guest
Old   November 24, 2003, 08:58
Default turning off error messages and resetting flow time
Phil
I have a couple of questions:
Is there a way to turn off the error messages whilst fluent is iterating? i am particularly interesed in turning off the report of reversed flow.
is there a way to reset the flow time during an unsteady calculation? I thought it could be done using the TUI but I cant find the correct command
Old   November 24, 2003, 09:35
Default Re: turning off error messages and resetting flow
solve/set/flow-warnings
enable flow warning messages? [yes] no
The above will switch off the reverse flow warning messages.
(rpsetvar 'flow-time 0.0)
Will reset the time to 0 sec.
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
TimeVaryingMappedFixedValue for Direct Numerical Simulation inlet johndeas OpenFOAM 5 May 21, 2014 07:11
resetting flow timer ssn FLUENT 0 January 2, 2008 13:09
resetting time to 0 K. Kevala FLUENT 1 March 3, 2004 04:46
