flow in pipe
Old   December 4, 2003, 22:05
Default flow in pipe
co2
I have a simple pipe flow and I am trying to get the fully developed profile for both velocity and temperature. Hence I have modeled it to be long about 50 times the diameter. But I am not sure what inlet and outlet BC combinations I should be using.
Do I use Velocity inlet + pressure-outlet?
OR
Mass-flow inlet + pressure-outlet?
Please let me know
Old   December 5, 2003, 03:29
Default Re: flow in pipe
ccc
hi co2,
How about the compressibility of the fluid in your case? In general, velocity inlet is adopted for incompressible one and mass-flow for compressible one, especially ideal gas.
good luck.
Old   December 5, 2003, 10:54
co2
I dont worry about the variation in rho. it is water. so I guess vel inlet is taken care of. what about the outlet? it is pressure outlet or outflow?
Old   December 5, 2003, 12:18
ap
Velocity inlet is the appropriate BC for your case (incompressible fluid).
For the outlet, if you know the pressure at the outlet, use a pressure-outlet BC. If you don't know it, switch to Outflow BC.
You want to model a fully developed flow, so Outflow can be a good choice.
Hi
ap
Old   December 6, 2003, 10:22
ccc
hi co2,
I agree with ap.
good luck.
Old   December 21, 2003, 18:39
chandra
i think no neccesary to doubt vel inlet or mass inlet, it depend to the fluid properties, it is not the must to make vel in let for incompressible,
LES transitional pipe entrance flow hasanduz Main CFD Forum 2 October 11, 2013 17:59
HTC in Pipe flow subsemitonium CFX 6 May 6, 2013 22:00
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 20:41
Pipe Flow Saima CFX 1 January 10, 2011 16:41
