setting uds diffusivity
Old   January 14, 2004, 10:41
Default setting uds diffusivity
Andrew Garrard
I am also trying to simply set the diffusivity for three uds's. Has anybody any idea why, when solved, the diffusion coefficient for uds 0 and 2 has the same value that is set for uds1?
DEFINE_DIFFUSIVITY(uds_diffus, c, t, i) { if (i = 0) {return 28;} if (i = 1) {return 2;} else {return 1e-9;} }
Old   January 15, 2004, 05:44
Default Re: setting uds diffusivity
Andrew Garrard
Don't worry, I got what it was after a nights sleep. I used an assingn statemnet instead of a conditonal one. = / ==.
PEM modeling UDS diffusivity in mixture gemini FLUENT 6 August 7, 2012 07:37
What is UDS diffusivity of a self-defined material? aleisia FLUENT 0 March 5, 2011 22:08
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
UDS DIffusivity... up FLUENT 4 July 16, 2001 08:11
