Free surface wave pattern generation
Old   December 31, 2003, 08:38
Default Free surface wave pattern generation
sam
dear users,
actually i want to analyze the wave pattern generated by any body e.g. a cube which is half submerged in water and remaining in air, cube is moving with velocity of say 1 m/sec.now my question is that how i will model that problem in gambit and how can i deal with the free surface in fluent. Please guide in this problem. I will be greatful to all of you if you will tell me the correct way to simulate this problem. Thanks in advance.
Old   January 2, 2004, 16:12
Default Re: Free surface wave pattern generation
mateus
Hi!
You are going to work with Vof model in fluent. In gambit you define a geometry - is wise to work with structured mesh in this case. You are going to have some problems defining the boundary conditions. I recomend you the velocity inlet and pressure outlet. The initial water level can be patched to your geometry in fluent (chech the vof tutorial). The biggest problem your going to face is wave reflection at boundaries - the easiest way to avoid this is by makng a mesh really big so the wave amplitude is damped when it reaches the boundary.
Also check the previous messages on the forum - im shure youll find something
hope i helped
regards
MATEUS
UDF Defining VOF Free Surface at Outlet Alex Fluent UDF and Scheme Programming 13 August 8, 2012 16:50
wave pattern surface of floating object soeren87 OpenFOAM Running, Solving & CFD 6 June 29, 2011 08:34
Free surface water wave profile John N. FLUENT 0 February 2, 2009 16:17
Modelling free surface waves with wave parameters utku FLUENT 0 December 6, 2004 08:30
sphere in a free surface (thin film)flow Vasu Veerapaneni Main CFD Forum 0 September 15, 1998 17:32
