December 31, 2003, 08:38 |
Free surface wave pattern generation
dear users,
actually i want to analyze the wave pattern generated by any body e.g. a cube which is half submerged in water and remaining in air, cube is moving with velocity of say 1 m/sec.now my question is that how i will model that problem in gambit and how can i deal with the free surface in fluent. Please guide in this problem. I will be greatful to all of you if you will tell me the correct way to simulate this problem. Thanks in advance. |
January 2, 2004, 16:12 |
Re: Free surface wave pattern generation
Hi!
You are going to work with Vof model in fluent. In gambit you define a geometry - is wise to work with structured mesh in this case. You are going to have some problems defining the boundary conditions. I recomend you the velocity inlet and pressure outlet. The initial water level can be patched to your geometry in fluent (chech the vof tutorial). The biggest problem your going to face is wave reflection at boundaries - the easiest way to avoid this is by makng a mesh really big so the wave amplitude is damped when it reaches the boundary. Also check the previous messages on the forum - im shure youll find something hope i helped regards MATEUS |
UDF Defining VOF Free Surface at Outlet | Alex | Fluent UDF and Scheme Programming | 13 | August 8, 2012 16:50 |
wave pattern surface of floating object | soeren87 | OpenFOAM Running, Solving & CFD | 6 | June 29, 2011 08:34 |
Free surface water wave profile | John N. | FLUENT | 0 | February 2, 2009 16:17 |
Modelling free surface waves with wave parameters | utku | FLUENT | 0 | December 6, 2004 08:30 |
sphere in a free surface (thin film)flow | Vasu Veerapaneni | Main CFD Forum | 0 | September 15, 1998 17:32 |
