open mesh files in gambit
Old   February 8, 2004, 07:38
Default open mesh files in gambit
A.Naser
how can I open the mesh file which is available in Fluent CD in the gambit inorder to modify the geometry or the boundary conditions?
Old   February 8, 2004, 08:00
Default Re: open mesh files in gambit
ROOZBEH
Hi; You should in Gambit at first set the solver to Fluent, then go to the "file" menue and "import" your mesh file (not case file)from your working directory of Gambit.
Hope this help you!
Roozbeh Mousavi
Old   February 11, 2004, 16:22
A.Naser
ERROR: The Fidap Neutral file header (record 1) is non-standard.
This is what I got when I tried to follow your procedure!
Old   February 20, 2004, 05:39
LLG
Simply answer: do not try to open mesh in gambit.
If you create gambit geometry it is stored like vectors. Mesh contains set of points.
I tryed to export mesh and re-read mesh but it caused data loss... Use gambit files instead...
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
How to open mesh file in Gambit /pls help FRAJ FLUENT 14 February 19, 2017 01:36
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
Reading mesh files into Fluent from Gambit Prabhu.B FLUENT 4 July 16, 2002 19:03
