3D Gas Turbine Combustor
Old   February 9, 2004, 15:36
Default 3D Gas Turbine Combustor
Ehsan Alborzi
Hi I am using fluent 6 for modeling a 3d gas turbine combustor.(Kerosen+air) I want to solve it firstly with cold flow but i dont know why i have reverse flow even in inlet.The dimensions are taken from lab.i was thinking that it is related to the lenght of combustor.i changed it but i still have the same problem. Whenever i change the flow direction from component to normal to boundary the revese flow will disapear. actually i want to see the swirling flow arround the air swireler. So you are kindly requested to help me with this concern. 2. i am not able to set my viscous model boundary condition for air swirling. Regards
Old   May 18, 2012, 05:17
juzer_700 is on a distinguished road
Hey, I'm trying to simulate combustion chamber (cold flow) in ANSYS FLUENT> BUt it is showing reverse flow. I am actually simulating in 2D-Axisymmetrical. I want to see the effect of swirl, so I mentioned the swirl number.
Am I doing anymistake.
Did you manage to correct your simulation and succeded in doing it?
Please reply.
juzer_700 is offline   Reply With Quote
Gas Turbine combustor inlet boundary condtions jose_rodrig OpenFOAM 3 May 18, 2012 07:13
simulate a gas turbine combustor with dieselFoam kikko OpenFOAM 0 September 23, 2011 20:32
pressure drop in gas turbine combustor hosein azadi Site Help, Feedback & Discussions 1 June 8, 2010 10:20
Gas Turbine Combustor Data cfd_user CFX 0 August 10, 2000 16:40
Gas Turbine Combustor Data cfd_user FLUENT 0 August 10, 2000 16:37
