iam doing project in two phase flow in double pipe heat exchanger(condensor).Is fluent will support the two phase flow.if it.then how we can give the boundary condition.i need some help regarding this two phase flow in condensor(HE).any one help me in this,it will be useful for my project thanking you yours truly apremanand
hi, if ur sysytem is turbulent then depending upon model used.. u can define one phase as primary and other as secondary. the for primry phase u have to enter the volume fraction, which u can calculate by knowing the volume flow rate of both the streams.
alfurqan halim
Rep Power: 0 ![]() |
i have same problem with you..
i already try to use multiphase volume of fluid.. but, for the result i'm not sure it is correct because it is error when it iterate.. do you use energy equation? what model do you uses? k- epsilon? |
problem in Phase Field method | qunwuhe@hotmail.com | Main CFD Forum | 6 | February 16, 2011 12:20 |
convergence problem of three phase flow | nick | CFX | 3 | April 25, 2008 09:00 |
error in two phase flow problem | mvee | FLUENT | 0 | March 28, 2007 05:17 |
Multi Phase option problem.... | Christos Sfyris | Siemens | 1 | May 22, 2003 07:53 |
Help - Two Phase Flow - Convergence Problem | R.Sureshkumar | Main CFD Forum | 1 | February 22, 2000 03:24 |
