Von Karman 2D Stable, no shedding
Old   March 10, 2004, 05:43
Default Von Karman 2D Stable, no shedding
Stephen Mar
I am trying to simulate the shedding of Von Karman Vortices from a 2d cylinder. However I am only seeing steady no shedding results. I have read the posting on this site, which appear to indicate that a disturbance is required before the unsteady result will be achieved. If this is the case could someone give me an Idea of what disturbance is required and how I could go about it.
Cheers!! in advance!!
The problem is set up as follows Re = 70
V = 0.001
D = 1
Fluid = Air
Domain is ten cords with Circular shaped
Velocity inlet, and velocity outlet (No external walls)
Model = Laminar
Time step = 0.00001
Have tried altering the relaxation factors
Old   March 10, 2004, 10:13
Default Re: Von Karman 2D Stable, no shedding
paul
Stephen
If you have a look at the validations that are posted up on the Fluent website for Fluent 6.0, there is a validation that uses the vortex shedding around a cylinder. They give details about the disturbance required to initiate the vortex street.
Hope this helps
Paul
Old   March 10, 2004, 16:46
Manuel
Hi Stephen
The use of a disturbance may not be necessary. At least I runned this flow test some time ago for Re=100, and obtained the transient flow with good accuracy.
If your mesh is coarse or you are using first order upwind for the discretization of convective terms you may not obtain the shedding as expected.
Try using QUICK in the discretization of convection. I think it will be enough (Solve->Controls->Solution->Momentum->QUICK).
Of course you should use the unsteady solver, preferably with second order accuracy. Your time step should also be well chosen.
For Re=70 -> Strouhal = 0.15 (approx) so:
T (period) =1/f=D/(U*0.15)=1/(0.001*0.15)=6670 s
So using dt=1E-=5 you will need 667000000 time steps per shedding cicle !!!
You should use a time step of order of T/100, i.e. around 5 sec.
Hope this help, Cheers Manuel
Old   March 16, 2004, 14:48
Stephen Mar
Thanks! Paul and Manual,
The help was much appreciated
Cheer!!!!!!
Are these reverse von karman vortex street? quarkz Main CFD Forum 1 August 20, 2009 15:15
wmake compiling Problem with OF1.5 openTom OpenFOAM Installation 4 May 3, 2009 14:44
Numerical damping in 2D Von Karman Kristine FLUENT 0 March 11, 2004 11:50
Vortexes shedding (von karman vortexes) Mahdy Karzar Jeddy FLUENT 1 August 11, 2002 22:25
Von Karman Integral Length Scale Txingurri Main CFD Forum 0 May 2, 2002 12:05
