periodic boundaries
Old   April 9, 2004, 13:40
Default periodic boundaries
Will
I am simuilating a combustor section in an annulus combustor. I read in Fluent manual that to check periodic boundaries use grid/check and that teh difference between the minimum, maximum, and average should have negligible values and if they do not then something is wrong with grid. Now if you view entire geometry with periodic repeats then the entire geometry is very large, but I am only simulating a section of combustor. Now my model does not show a change in the max,min, and average in grid check. What can be wrong? Could it be that my entire geomtry is so large? or that my section is small? thanks
periodic boundaries Mary FLUENT 27 January 6, 2021 01:54
CGNS import in fluent - periodic boundaries. Bjarne Børresen FLUENT 2 April 25, 2013 11:12
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 14:06
periodic boundaries - flow through a net PK FLUENT 0 July 12, 2007 11:58
Periodic Boundaries in GAMBIT!! swetha FLUENT 1 November 26, 2006 22:02
