Export option In Gambit
Old   April 9, 2004, 03:12
Default Export option In Gambit
krishna
Hi Ppl,
I am currently working in Mesh generation around a solid cylinder (3D), wherein the flow characteristics over a cylinder is to be studied, I am supposed to read the mesh file developed in Gambit, into Techplot 8.0, so that further computations can be done, I happened to try all of the export options given by Gambit, but nothing turned to be gud enough to read into Techpolt.
Thanks in Advance,
krishna
Old   April 9, 2004, 11:04
Default Re: Export option In Gambit
David
I'm not sure you can export a gambit file into techplot. i know you can read data files from Fluent into techplot but i believe gambit export mainly to CFD packages.
regards
David
Old   April 9, 2004, 11:13
leung
Tecplot can only read the data and case file generated by fluent or airpak
Old   April 9, 2004, 20:01
krishna
Thanks Leung,
So if possible,can u tell me in which software shd i create my mesh so as to read it in Techplot.
Thanks in Advance,
krishna.
krishna
Thanks David,
Thanks in Advance,
krishna.
Old   April 9, 2004, 21:24
David
Hi Krishna,
Unfortunately I'm not aware of any meshing software where you can export directly to techplot.
What i would do is create my mesh using Gambit, run my computations using Fluent, and then export the Fluent files to Techplot.
i hope this helps
David
PS: i know a former PhD student from RMIT who has done some CFD as well
Old   April 9, 2004, 22:32
krishna
Hi David,
Thanks a lot for the reply, actually I want to read the mesh files into Techplot, so that I can device my own solver,using some Programming language like C,C++. The other option is I can program in Matlab, again the problem of reading grid into Matlab may pose a problem, and I am not sure which software can do the procees of Reading mesh into Matlab for further use. If u have any idea plz do share...
Thanks in Advance...
krishna.
PS:Plz let me know the person u know in RMIT
Old   April 10, 2004, 02:18
leung
you r supposed to do the meshing in gambit
1. Do the meshing in gambit 2. Export the mesh in gambit 3. Open Fluent and read the mesh as case. file (*.cas) 4. If possible, generate a set of solution in fluent
( tecplot can't read case file alone) 5. save all the case and data file (*.cas and *.dat) 6. Use tecplot to import all the (*.cas and *.dat) file 7. After imported into tecplot, you will have your mesh geometry and the solution (eg, vector field), you can only turn on the mesh option without showing and contour/vectors
Old   April 10, 2004, 03:08
krishna
Hi Leung,
krishna.
Old   April 12, 2004, 08:04
David
Hi Krishna,
I really have no clue on how you could process further into reading your mesh into techplot through your own solver. I'm afraid i do not have the expertise.
regards
David
I sent you an email concerning the person from RMIT
combustion problem mcnair CFX 9 March 22, 2011 14:06
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
Single Bubble Gerrit Senger CFX 4 March 12, 2007 16:29
