April 15, 2004, 21:43 |
URGENT!! Help on Throttle body poject.
I am working on a Formula SAE project, I reqired to create a 3D model and determine the air mass flow through the throttle body, which basically is a converging-diverging nozzle. what i did so far was created a cylinder as domain with the vol of the throttle deducted at the end of it, then i mashed with Hybrid/tri, then set the 3 sides of the cylinder as pressure inlet (1 atmo), the sides of throttle as wall and the end of the diverging section as pressure outlet. then i ran a inviscous flow model, but the solution diverge after 10 iterations and have floating point errors, also the velocity of flow is not right. can anyone explain to me what floating point error is and how imporant convergant is? also what is the different between pressure-far field and pressure inlet and outflow-vent. do you racken i have set up the model correctly?
How to make appear edge/line body (created in design modeler) in the meshing tool | Rockda | ANSYS Meshing & Geometry | 6 | June 8, 2016 23:10 |
6DOF with floating body bounce back. | paka | FLUENT | 4 | June 6, 2013 11:32 |
Body in windtunnel - high preassure behind the body? | Andyjoe | OpenFOAM | 4 | February 16, 2010 10:57 |
Body force at the cell face | Souviktor | Fluent UDF and Scheme Programming | 0 | March 31, 2009 08:54 |
HOW TO GIVE BODY HEAT GENERATION TERM | NITUL KALITA | FLUENT | 3 | December 18, 2008 11:23 |
