initialization
Old   April 21, 2004, 15:52
Default initialization
co2
question: In a particular 3D unsteady problem let us say I obtain solution for some first 20 time steps by using very low under relax parameters. Now that the flow is developed, I want to start again at t=0 and use good values (default) for under relax parameters. How do I use the solution obtained previously to initialize my new problem?
Old   April 22, 2004, 05:23
Default Re: initialization
ap
You can export the solution using the File->Write->Profile command from the first grid, initialize your solution and reading profiles again.
Maybe there is a better way, but I don't know it.
Hi
ap
Old   April 22, 2004, 10:15
co2
does profile files contain all the data at nodes ? i was thinking the dat file does that
FMG initialization query Mohsin FLUENT 6 November 2, 2016 02:02
code initialization - exclude pressure edna Siemens 0 January 29, 2008 10:56
Initialization a student Siemens 2 May 19, 2006 12:55
compressor initialization paglia FLUENT 0 February 1, 2006 15:14
INITIALIZATION & SORSCA july Siemens 1 May 31, 2002 02:55
