negative vol
Old   April 26, 2004, 11:48
Default negative vol
roy
Hi, After importing the mesh file into fluent when I check the grid it always gives me negative vol and grid check failed. I tried many elements in gambit to change the mesh file like quadralater/tetrahedral/triangular. But it always gives -ve vol. I would really appreciate your help.
thanks
Old   April 26, 2004, 16:39
Default Re: negative vol
xfshi
do mesh again
Old   April 27, 2004, 04:09
zxaar
i would like to share that happened a week ago, i am not sure how much this will be help to you.
we created a simple two D mesh (A STRUCTURED one), and did some analysis on it. well since the results were not matching well with the experimental values, we dicided to refine the mesh. at some point of time, it happened that after importing fluent gave us 'neg-volume' error.
the reason for that might be: after a perticular level of refinement, the mesh becomes so small that spatially difference in vertices do not go well with error tolerances of fluent (i am assuming vol is calculated by Gauss theorum ... sum( Xi * Ax) over all the surfaces of vol) . so after just coarsen a little bit the neg-vol error disappeared.
check if this is the case with your mesh.
Old   April 27, 2004, 09:38
Bob
It's funny. I recently had a mesh done in Gambit that produced negative volumes. I spent hours trying to resolve the issue. So I decided to go ahead and import into Fluent. When I did that and checked the mesh Fluent reported no negative volumes. I have no idea why that happened.
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
blockMesh error ... balkrishna OpenFOAM Pre-Processing 0 August 17, 2010 02:39
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
