energy source term W/m3
Old   April 24, 2004, 19:45
Default energy source term W/m3
co2
hi all,
I am running a 2D axisymmetric unsteady problem. I have a solid zone for which I want to specify engery source terms (W/m3). I have these values in a profile file and I am reading those values from there. But when I try to run my model, I get access violation erro. It gives some chip-exec error and tells me that the particular term in the profile file can not be accessed. following are the details
Error: chip-exec: function "qvolTANK2" not found. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
Has anyone come across this error? what is the solution?
Old   April 25, 2004, 10:46
Default Re: energy source term W/m3
co2
hi,
i solved this problem by writing a simple define source udf.
is it true that profiles files can not be used for writing source terms in Fluent?
Old   April 25, 2004, 21:35
FJ
No, you can't specify it.
Profile file is for a certain face value at specified BC.
FJ
Problem of SOURCE term gradient in UDS wind Fluent UDF and Scheme Programming 6 December 1, 2022 14:21
add source term to energy equation by udf tomas Fluent UDF and Scheme Programming 7 September 10, 2013 02:08
Mass and energy source - evaporation neilduffy1024 ANSYS 4 July 16, 2013 23:50
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 12:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
